E4OD solenoid pack
Old 01-10-2016, 07:02 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
E4OD solenoid pack
I have a 97 f250 heavy duty with a 460 with the e4od built 7 of 97 was wondering if there is a difference between the 95 and 96 and by your truck in the solenoid packs because I keep having transmission issues bought one from Monster transmission the first go around last at 80 miles and the second last at 23 miles don't know if there's a difference in the solenoid packs causing the ECU to be confused and throw the truck into limp limp mode causing the transmission to be at full pressure any help on this matter would be helpful
Old 01-10-2016, 08:52 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
I don't know of a difference. Maybe the solenoid pack isn't the problem.
Old 01-10-2016, 08:59 PM
wtroger's Avatar
wtroger
wtroger is offline
I have had the relief valve in the front pump stick both ways. Closed way to high pressure. Open no pressure.
Old 01-10-2016, 09:09 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
Just not sure what else would be a problem on a new transmission unless there's something different on the solenoid packs causing it to burn itself apart I put a used one in and need the newer pack and just want to make sure that if I buy a pack that is not going to mess up this transmission
Old 01-10-2016, 10:22 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
you bought a reman trans with no warranty?
Old 01-10-2016, 10:32 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
It was from monster transmission they want 500 dollars for me to ship it back to them the first time second time they wanted 500 bench fee and 500 to ship it back and since the first one burnt up after 80 miles and the second after 23 I thought another 1000 dollars wasn't worth it
Old 01-10-2016, 10:35 PM
FORDF250HDXLT
ouch.id start talking to them about getting your money back.whats making you suspect a bad solenoid pack?
Old 01-10-2016, 10:37 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Too bad these details were not known before you bought it...... It's a pretty good deal for them, get paid again even if they screw up.... WOW
How long have you had the transmission?
Old 01-10-2016, 10:44 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
Already did said nothing they can do suprise suprise that's why I think it's the solenoid pack is the problem they kept telling me it's obd2 and it's obd1 but I really can't find a difference besides the number 12 pin in 97 goes to a pcm power and on 96 it's a pressure control circuit but can't find any other information than that I'm at a loss
Old 01-10-2016, 11:32 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
February of 2014 picked the truck up in June of 2014 and transmission has been out of truck since July 2014 didn't even make it 2 months
Old 01-11-2016, 10:33 AM
RIKIL's Avatar
RIKIL
RIKIL is offline
Some reference material that may apply...fun reading
Old 01-11-2016, 10:41 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
Just not sure what else would be a problem on a new transmission unless...
Any diagnostic codes pulled either time?
Old 01-11-2016, 01:56 PM
subford's Avatar
subford
subford is offline
Does not sound like a transmission problem.
You need to do an KOEO electrical test and see if there are any codes in CM by letting the test run after the electrical test if you have not disconnected the battery.
Old 01-11-2016, 02:19 PM
Jmitich's Avatar
Jmitich
Jmitich is offline
Don't have a ford scanner everything on mine says there are no codes
Old 01-11-2016, 03:01 PM
Scndsin's Avatar
Scndsin
Scndsin is offline
If the check engine light comes on as a self test when the key is turned to On, you can check the codes with a short piece of wire. No CEL, then use a test light (you can rig up a light bulb & 2 pieces of wire), or an analog volt meter:
Ford ? OBD Trouble Codes
Quick Reply: E4OD solenoid pack
