Dome light problem
Old 01-10-2016, 05:51 PM
Jointasset's Avatar
Jointasset
Jointasset is offline
Dome light problem
I pulled my bulbs out today to switch them to led's and I guess I snapped the metal loops that go around the bulb shroud. Can you order the "loop"/ribbon connector that connects into the overhead console?
The following users liked this post:
Old 01-10-2016, 06:41 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
I doubt that printed circuit was ever available as a stand alone part. In your search you may want to look for the whole light assembly.
Old 01-10-2016, 08:51 PM
03X's Avatar
03X
03X is offline
it will still work. Mine is broken like that and still works (as long as they arent broken on both power and ground leads). if not you can solder a tiny wire across on the metal spots
Old 01-10-2016, 09:14 PM
agsmv1's Avatar
agsmv1
agsmv1 is offline
If you look in the tech folder you can totally do away with them to add LED's. Thats what I did.
https://www.ford-trucks.com/forums/1...l#post12206868
Old 01-11-2016, 01:15 PM
Jointasset's Avatar
Jointasset
Thanks AGS- found that last night and just finished it at lunch. Pretty simple- took me about 30-45 min.
Old 01-11-2016, 03:02 PM
Jointasset's Avatar
Jointasset
So I blew a fuse(#35) when I tapped the broken ends of the ribbon cable together before I decided to do the above mentioned mod. Replaced the fuse and all was fine w my lights, inst. cluster, etc. However, now my drivers power seat will has no "movement" at all but the heat works. Looked at fuse 112(left hand power seat), appeared fine but replaced anyway w no luck. The passenger seat works.
Coincidence?
Old 08-17-2020, 12:09 AM
Bob Amerine's Avatar
Bob Amerine
Bob Amerine is offline
circuit
Mine are broken on one side and put both out of service. Can you get that circuit of hammered flat wire or do we need the entire assembly. What a headache a dome light can turn into.
Old 08-17-2020, 08:15 PM
2002Ex's Avatar
2002Ex
2002Ex is offline
Coincidence?
LED's are notorious for causing electrical system problems. They draw far less power and can interfere with other things that operate on that circuit.
Test your seat circuit to see what power level is there at the connector.
ibjew
2009 - 2014 F150
12-16-2017 10:50 AM
xmontex4
1999 to 2016 Super Duty
15
03-21-2012 06:56 AM
Braker 19
1997 - 2003 F150
03-09-2011 08:45 AM
DznyRulz
02-10-2010 05:20 PM
askopp
12-14-2006 02:04 PM
Quick Reply: Dome light problem
