Size of fuel tank
Old 01-09-2016, 09:44 PM
WXboy's Avatar
WXboy
WXboy is offline
Size of fuel tank
The build sheet on my truck says it's got a 26 gallon tank. But I'm still working on running out my first tank and the display shows that I've burned 27 gallons and the needle is on 1/4 tank mark. What's the deal with that? Is the display inaccurate or was there an optional tank size?
Old 01-09-2016, 09:52 PM
Liam_Harrow's Avatar
Liam_Harrow
Liam_Harrow is offline
Optional 36 gallon tank so if you had that tank 27 would make some sense for 1/4
Old 01-10-2016, 12:14 AM
brokenleg's Avatar
brokenleg
brokenleg is offline
how many gallons to fill it??
Old 01-10-2016, 05:44 AM
fastback89's Avatar
fastback89
fastback89 is offline
My 2013 crew cab has a 36 gal tank
Old 01-10-2016, 06:01 AM
eriebasin's Avatar
eriebasin
eriebasin is offline
If you have the tow package, it comes with a 36 gallon tank as others have mentioned. I find the Miles to E and gauge to be very accurate.
Old 01-10-2016, 06:55 AM
WXboy's Avatar
WXboy
WXboy is offline
Thanks guys. The dealership filled the tank up for me as part of the deal so I have not put any gas into the truck myself yet. The truck does have the heavy duty trailering package with the integrated brake controller on the dash so maybe it does have the 36 gallon tank. I guess it's going to take a lot of money to fill this thing up.
Old 01-10-2016, 01:19 PM
KJ Smith's Avatar
KJ Smith
KJ Smith is offline
..... so maybe it does have the 36 gallon tank. I guess it's going to take a lot of money to fill this thing up.
4X4 comes with a 36 gallon tank.
Old 01-10-2016, 04:16 PM
GuyGene's Avatar
GuyGene
GuyGene is offline
You are very fortunate indeed. The 36 gallon tank is a must on my next truck.
Old 01-10-2016, 04:26 PM
KJ Smith's Avatar
KJ Smith
KJ Smith is offline
Probably the main reason I got 4X4.
It is an option on the 2015 and up 2 wheel drives.
Old 01-10-2016, 04:47 PM
pb34's Avatar
pb34
pb34 is offline
I've got a 4x4 with the 26 gallon tank.
Old 01-10-2016, 06:03 PM
KJ Smith's Avatar
KJ Smith
KJ Smith is offline
When I was looking in '13, it was the 4X4's that had the 36 gallon tank.
Do you have the 7200lb GVWR and/or 3:55 rear?
Old 01-10-2016, 06:05 PM
pb34's Avatar
pb34
pb34 is offline
I believe I have the 3.55 rear. Not sure about the 7200b GVWR. I have the standard tow package. Not the max tow package.
Old 01-11-2016, 06:45 AM
WXboy's Avatar
WXboy
WXboy is offline
My build sheet lists the "heavy duty trailering" package. And I do have 3.55 gears. Were the 3.55s not standard? I can't imagine a numerically lower ratio in a full size truck.
Old 01-11-2016, 06:54 AM
bakon's Avatar
bakon
bakon is offline
Park that 1/4 tank left on a 36 gallon on an incline and it might not start....pick up in rear. Trust me on this... Also never got more than 33 in it. Miles to empty and gauge accurate, the gallons used on trip meter, not always right.
Old 01-11-2016, 05:39 PM
KJ Smith's Avatar
KJ Smith
KJ Smith is offline
For the most part...
Trucks with 18" wheels have 3:31
Trucks with 20" wheels have 3:55
Max Tows have 3:73
Quick Reply: Size of fuel tank
