transmission slipping out of overdrive?
Having trouble with my 97 f350 powerstroke automatic transmission? The truck down shifts out of overdrive then picks it back up, it was rebuilt about 10,000 miles ago. I replaced the third break light recently because it was a rats nest, figured it would solve the problem but to no avail.
Long story short it's not throwing
any codes, no idiot lights or anything, trans fluid level is spot on, let the truck warm up for 30 minutes figuring it was slipping due to the cold. Please help lol
Someone said it could be turbo lag but this seems more like a transmission issue.
That 3rd brake light only matters because something is drawing its ground connection through it. You may want to check all the ground wires. I had a 97 some time back, and it was acting goofy. It didn't have that 3rd brake light, since it was an F-Superduty. I was advised to check all ground wires running from the body to the frame as well as the batteries. I also ran 2 more ground wires off both batteries, one each to the body, and one each to the motor. And it cured the electrical gremlins.
Received 3,102 Likes
on
on
