2011 F150 instrument cluster issue
town and all shops nearby have a week wait to get the truck in there. This happened once or twice a year ago but I'd pull over, shut it off and when I restarted it everything was fine. I'll be driving and all of a sudden the information display on the cluster will show a wrench signaling something's wrong(see image), then the speedometer will go to 0 and all information in center display will show flat lines. This started up yesterday but is now doing it after about 10min of driving every time I being driving. What's worse is the truck will randomly start shifting or shift extremely hard even when driving at a consistent speed.
Has anyone seen this before and if so what can I do?
Thanks, Aaron.
This was taken while truck was going about 45, but shows 0
Thanks, Aaron.
Thanks, Aaron.
Thanks, Aaron.
I can't say that I've ever seen this before but I know sometimes when people's batteries start to go they can do some funky things. Have you had your battery load tested or tried replacing the battery?
town and all shops nearby have a week wait to get the truck in there. This happened once or twice a year ago but I'd pull over, shut it off and when I restarted it everything was fine. I'll be driving and all of a sudden the information display on the cluster will show a wrench signaling something's wrong(see image), then the speedometer will go to 0 and all information in center display will show flat lines...
Crystal
It sounds like your cluster is losing CAN communication with the other modules in the vehicle. This could be trouble with the cluster receiving the info, or it could also be the PCM sending the info. The good news is that we can repair both. It could also be faulty wiring on the vehicle though.
The proper way to troubleshoot this would be attempting to communicate with each module when the blanks are is played across the display. Whichever module is having trouble communicating with the scan tool will point you in the right direction to start.
'94IDITurbo7.3
22
12-09-2012 11:17 AM
