Tow mirror glass shaking/moving bumps and highway speed?
So on my new 2016 F-150 the glass in the passenger side mirror appears to shake or move with the smallest bumps in the road.
It's not so bad that the mirror is useless but it's annoying. Is there a "fix" I can do or is this "normal"?
I should be more clear - the housing itself is not moving and is rock solid. It's the glass itself that appears to be vibrating. Just the upper part that you can adjust electronically - the bottom curved mirrors are rock solid .
Upon close inspection both sides do it - but passenger side moreso.
We had the exact same issue on ours. It was only on full extension, I noticed it pulling my boat. yes, the top mirror did vibrate some, no a big deal, but it was noticeable.
I did nothing, but now it is either not an issue, or I just got used to it.... I don't even notice it now, so maybe it tightened itself up after it was drive some...
I've had this problem on previous Fords, I don't think replacing the mirror will help. I think it's a design flaw. My Lariat with standard power mirrors do it. Drivers side the worst. Depends on wind direction on how bad it is. I've just learned to deal with it. However, let me know if replacement works and I will add it to my list when I get first oil change. Seems to keep growing...
Well the issue isn't that the whole housing is moving.
As an example - when I was pulling my trailer if I look in my top big flat mirrors it looks like my trailer is bouncing all over the road up and down, side to side.
If I look in the convex mirrors at the bottom I can see the trailer is perfectly still and planted behind me - not moving up and down or left and right.
In short- the top glass in the mirror shakes like crazy, the bottom glass does not. The housing as a whole does not visibly shake but is clearly shaking on some level otherwise the glass wouldn't be shaking I imagine.
I figured it was just the nature of the design at this point.
I've got the same problem with the towing mirrors on my 2016. My dealer tried to tell me it was because of the size of the mirror. That idea didn't fly because I had the towing mirrors on my 2010 and they never budged. Before I left they admitted that Ford is aware of the problem, but no fix as of yet.
Mine doesn't vibrate any more than I would expect for a big dumbo ear sticking out in the wind... certainly no more than the 09 F150 with TT mirrors I drove previously.
I do notice a lot of "ghosting" effects from (presumably) the electrochromic coating on the driver side mirror, which drives me nuts. I can barely read a license plate on a vehicle behind me.
