Can someone explain this to me? - Ford Truck Enthusiasts Forums
Old 12-31-1969, 06:00 PM
Guest
Posts: n/a
Old 02-10-2002, 01:45 AM
might_b_giant might_b_giant is offline
might_b_giant is starting off with a positive reputation.
About a year ago i was driving my '88 F-150 when presto i had no power steering. I wrestled it back to work to find that all the fluid had poured out the bottom of the steering box. So i brought it to my friendly local wrench turner and had the seals replaced. Fast forward to friday night, I'm delivering pizza and the darn thing starts whinning a lot. I didn't lose it imidiatly like last time but when i got it back again it was dripping out rather quickly. Am i doing something wrong?
~eriC
Old 02-10-2002, 10:29 AM
bjoern bjoern is offline
bjoern is starting off with a positive reputation.
Had a similar thing happening to me. Apparently, if the gearbox is sufficiently worn, it takes more than just replacing the seals. I got a rebuilt gearbox from autozone...
Old 02-10-2002, 10:36 AM
orange peel orange peel is offline
orange peel is starting off with a positive reputation.
that whining noise is the steering pump without fluid, and i dont thing that your doin anything wrong, you cant do much of anything wrong with it except turn the wheel alot. ive been told if you hold the steerin wheel all the way over and hold against that little stopping point its bad for it though. it was in my manual.
Old 02-11-2002, 04:16 AM
madman666's Avatar
madman666 madman666 is offline
madman666 is starting off with a positive reputation.
When you totally drain the power steering pump, and lines to clean out all the old fluid, and then you go to refill the system, the ford pumps have a hard time getting all the air out, which causes the winning noise. Most times it never goes away.
This is what I have been told, so it may not be accurate.
Old 02-11-2002, 11:43 AM
stevieray stevieray is offline
stevieray is starting off with a positive reputation.
Three things that are for sure, death, taxes, and Ford P/S pumps whine!
Old 02-11-2002, 02:43 PM
460lover 460lover is offline
460lover is starting off with a positive reputation.
Once I get a job, I am going to replace mine, cause mine is whinin and losing a lot of fluid. You just answered the question I was going to ask. Thanks a bunch, 460lover.
Old 02-11-2002, 04:17 PM
sam_1857 sam_1857 is offline
sam_1857 is starting off with a positive reputation.
I just bought a 95 F-150 SC, i6. This thing whines whether it's just idling and sitting still or turning or going down the road - ie, all the time. It does not leak brake fluid though.
My father-in-law is a mechanic and said the same as madman666. It's difficult to get the air out of the brake lines. I'm going to try to fix it, at some point.
sam_1857
Old 02-11-2002, 05:36 PM
thejerold thejerold is offline
thejerold is starting off with a positive reputation.
I had the same thing happen to me. I have an 86 F-250 company truck and the seal went out of the steering box.I had a new seal put in and two days later it blew out again. Had to spring for a new gear box. I guess once they are worn too much even a new seal won't help.
Old 03-28-2014, 03:29 PM
fordmanjones fordmanjones is offline
fordmanjones is starting off with a positive reputation.
first time on here so still tryin to figure it out but I need help. Im having issues with my 91 f250 with 460 , I had tranny rebuilt about 7-8 months or so ago and every now and then it would die in reverse it quit so no biggie but last week me and a buddy changed the fuel filter and I acted a little funny I thought maybe air working its way out but then it started dieing when I put into drive and reverse but was ok when I finally got it moving . its also shifting hard into 2nd gear. any ideas
Old 03-28-2014, 07:56 PM
mrrish79's Avatar
mrrish79 mrrish79 is offline
mrrish79 is starting off with a positive reputation.
I suggest you start a new thread with your questions.
Old 03-09-2016, 12:40 PM
Kleinn Air Horns Kleinn Air Horns is offline
Former Vendor
Kleinn Air Horns is starting off with a positive reputation.
I know it may be a sin to say this but Wild Horses Bronco in Lodi, CA used to sell a bracket to convert to a Saginaw PS pump. No whine and a powerful pump. Been a while since I dealt with them. But I would imagine they still build it. WILD HORSES 4X4 Off-Road Bronco Parts and Accessories
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
fdgdfgdf nmclella Testing..... 0 04-12-2015 05:23 PM
cgh lawdawg79 1999 to 2016 Super Duty 0 04-09-2015 08:04 PM
exhaust tugboat Exhaust Systems 3 09-20-1999 01:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
