Safe jacking points on the 2003 Escape?
Are there safe jacking points on the 2003 Escape so I can get both front or rear wheels off the ground at the same time with a floor jack? I suspect not, but I thought I'd ask.
Also, where are safe places to put jackstands? More often than not, factory manuals tell you to put the jackstands in the same place you're putting the jack, which is obviously useless.
Sometimes a real PITA but just use the listed support point for a jack stand and place my jack also as close as I can to that same point.
Mine is a 4WD and IIRC, support point doesn't differ from a FWD.
I'm also not using the factory jack (that has never been out of the vehicle) which I am sure fits into some groove at the factory lift point.
True, but been using it for 12 years and 295k miles. I can't see it failing to use it long enough to put stands underneath when I use it and leave it while rotating tires.
I could maybe see their point on a FWD not lifting at the center of the rear end but not on a 4WD.
Mine is a 4WD. Can I lift the rear end with the jack under the diff?
I don't like lifting one side at a time. I used to do that (before I discovered that it was safe to jack my Jeep on the rear diff), and after I'd set the first stand and was jacking the other side, I'd sometimes see the first stand start to lean. Scary. I much prefer to set both stands at the same time.
I had my 1978 Corvette on jack stands, wheels off installing calipers and was trying to bleed the master cylinder. It wasn't level so I was either going up or back down. On the right front side, coming down on the stand when I lowered it kind of quickly, the frame touched the stand, floated up about 2" before coming back down. In between I almost soiled my shorts!!
Jacking must have lifted it right off the stand on the left rear corner for whatever reason.
I've been a DIY wrencher long enough to know that what the book says, and what you can safely do, can be two different things
The book for the Jeep ZJ says that you should only jack at specific points on the frame rails. In fact, you can safely jack under the front or rear diffs to get both wheels off the ground at the same time. So much better than lifting one side at a time.
