ZF S5-42 transmission
#31
I read back through the thread, and its not clear what transmission/engine the OP currently has. He seems to be looking for an external slave model, but may currently have a internal slave mounted to a small block. So what do you currently have OP?
#33
#34
#35
Heard centerforce is good but you will pay for it. I went with a LUK clutch kit and flywheel because it was only about 200 total, and LUK make the motorcraft clutch components.
Are you competitively pulling sleds or towing above GCVWR enough to make a stock clutch slip?
#36
#39
#40
#41
#42
OK so I picked up a new master cylinder today gonna put it on tomorrow if the warm weather stays holding up. I found the bleed screw to bleed the system when I get the new master cylinder put on. Is there anything special I need to do to bleed the air out of everything or do I just need to have someone down below to shut off the bleeder and reopen it as I'm pumping the clutch?
#43
#44
NOPE, you do not "pump" the clutch and bleed like brakes. You need to read a manual or look at some u tube videos how to do this properly. Basically from memory you fill the reservoir and then go under and crack the screw to let the fluid trickle out (and allows the air bubbles to rise). I found that loosening the master cylinder bolts where the assembly went thru the firewall so that the line was tilted to allow the air bubbles to rise helped .....
That is news to me. That is how I have been bleeding these hydraulic clutches for 20+ years.
VERY similar to bleeding brakes. Just lay under the truck and have assistant in the cab. Have them push down the clutch pedal and as they start to push down, you open the bleeder. Once they bottom out the pedal, close the bleeder. have them let up and repeat. Keep doing until no more air bubbles(dont forget to check fluid level every 3-4 pumps)
#45
