Truck howls under throttle
01-08-2016, 08:43 AM
Sounds good. I'll get on that tonight after work. Hopefully the ground has dried out enough so I'm not covered in mud by the end
Also, thanks Everyone for all the help. I can't say enough how much I appreciate it.
01-09-2016, 06:51 AM
01-09-2016, 07:48 AM
I would bet that "brake leak" is a blown wheel seal and that is gear oil we're seeing.
01-09-2016, 08:59 AM
I just had the axle seals done on that side. And I'm losing brake fluid somewhere and that's the only wet spot.
01-09-2016, 02:46 PM
01-11-2016, 07:28 AM
So how do I tell what axle I have? Vin decoder wasn't very helpful.
here is a site that I found that has exploded views of 3 different rear axles for my year make and model
REAR AXLE for 1997 Ford F-250
01-11-2016, 08:17 AM
None of the pictures showed a floating axle, which yours should be.
01-11-2016, 08:19 AM
If it's still there, there should be a tag on the rear differential being held on by one or 2 of the bolts that hold the back cover on.
01-11-2016, 09:12 AM
Someone probably swapped an e250 or an e350 axle, which they are not floaters
01-11-2016, 09:13 AM
Floaters are better though right?
01-11-2016, 09:54 AM
Quote:
Originally Posted by
Jarrett Campbell
Yes. Take a picture of the rear wheel, without a hubcap or center cap if possible without pulling the tire.
01-11-2016, 09:56 AM
I will tonight. Thanks Guys for all the help... I know absolutely nothing about differentials
01-11-2016, 06:16 PM
01-11-2016, 06:44 PM
Thats a full floater with Limited Slip 3.55
01-12-2016, 07:50 AM
Get yourself a canvas drop cloth for laying on the ground. They are about 10 bucks and make these jobs a whole lot easier.
