1997 Project truck
#47
The Felpro ES72519 seal kit is available from any major auto parts store. Ford doesn't make a seal kit for the older OBS 7.3l engines anymore. Only tier 3 engines and up have a kit (from what the ford parts guy told me) That's why I mentioned that you have to buy 4 seals instead of 2. They come in a bag of 4. None negotiationable.
#48
There's no point in throwing a $65 seal kit onto a used cooler into a $300 truck that hasn't seen pavement in over 10 years. If this truck was a daily driver I would. I haven't decided if this vehicle is worthy of my time for a resto.
And- after reading your comment I called another Ford dealership parts guy and asked why so many seals for one cooler and he told me the same thing. It's a conspiracy?
#49
#50
I don't mean to be rude to u guys disregarding your recommendations but I'm only trying to get this rig back on the road. Trying to keep the price down due to my financial adviser/ wife. Where I see potential, she sees a $ pit. I did take a video of the truck running and plan to have it up on YouTube soon.
This coming weekend is replacing the fuel return line that now leaks near the vacuum pump and attempting to get the brake lines swapped out. Not to mention the rotors and such. All driveline fluids should be changed also. Once the truck can stop and go down the road I plan on getting it back to my shop. I will definitely post more pics soon.
#52
Some parts no matter ford chebby dodge, John Deere or whatever needs OEM parts to work right. If the cheap aftermarket parts were so good, then why would there be so many selling them. Every change points 4 times in a year? Aftermarket will do that . OEM will last year's. Been there done that many times.
#54
I'd recommend head gaskets as well for the psd's. Unless your making some serious hp. Oh and valve cover gaskets
#55
Originally Posted by z31freakify
I feel what your saying like with sensors only OEM, but seal, gaskets etc you can get away with aftermarket stuff well minus Injector O rings, those you cant cheap out.
#56
Update
drove the truck home to the garage and removed all brake lines. All rear brakes done. Lights fixed after I pulled out household hacked up extension cords from under the dash. BTW truck ran fine except for front end play in steering. Once the replacement driver side valve cover comes in to replace the one with the burned terminals, I'll drive it locally and shake the bugs out of it.
#57
The Felpro gasket set I installed hasn't leaked at all. I had this set of o-rings inspected by one of our PSSR reps and he claimed that the Felpro seals have the same quality and durameter as Caterpillars which I wholeheartedly trust. Peace of mind.
DEACON G
06-06-2011 08:08 PM
86sixbanger
11-01-2009 10:52 PM
