390 fuel mileage increase
Best bang for the buck would almost have to be a good tune up, to include a new distributor, and dial in as much ignition advance as the engine will tolerate without pinging or pre-detonation. Make sure your vacuum advance diaphragm is in good condition and connected. It alone provides about a 15% improvement in MPG compared to running without it. Not much in actual gallon terms maybe but every bit helps. I'd rebuild the carburetor, and take a close look at your plugs. You can probably use a bit smaller jet size if you are careful. Jet down till you get lean surge or bucking at steady cruise on highway, and then go back up a size or two. Keep in mind you need some leeway to account for temperature and altitude (density) changes.
Remember your truck is aerodynamically a brick, there's not much to be done about that.
I agree but we don't know where he's at right now mileage wise. Maybe he's only getting half of the potential range possible? Who knows this is why I asked.
Any engine in poor state of tune will dump raw fuel into the cylinders and wash out rings, foul plugs, dilute the oil, spew excessive pollution, trash the cat converter, fail smog, waste money, etc etc. It pays to keep a motor tuned up for reasons other than fuel mileage. Depending where it's at now a few tweaks could make a big difference help keep the engine reliable.
Smaller jets are not always the answer. On a 74 F250 4x4 I had new, Ford's solution to poor mileage was 2 sizes larger jets and advance the timing. Doubt if it made much difference though.
The best thing you can do on these trucks is slow down. The difference in fuel consumption between 65 and 55 is considerable.
With stock sized tires you are running about 2800 rpm at 65. You could go to 33s and drop that by a couple hundred. But tall skinny tires are hard to find and the talller the fatter which is counter productive to fuel economy. Unless you could find a set of the rare 19.5 wheels that were optional in the late 50s to mid 60s on 4x4s.
