WINTER FRONT
I have the GoFia winter/summer grill cover for my truck. Used the same style on 1996 F350 with good results. Has the padded solid cover with two openings for winter and the bug screen for summer.
The snaps are attached with 3M double sided tape. The tape adheres good and can be removed if needed. Might need to test any tape residue removal solvent in an area that is not noticeable.
Some of the mesh grilles require you cut out the old grille center to install the mesh. I did see a grille on eBay the other day that is a replacement for the grille with no cutting but the grille is black with the mesh in the center.
What is the thing behind your license plate?
on
kawakibi
6.7L Power Stroke Diesel
03-07-2013 12:49 PM
