rear bumper fitment question - 94 bronco
I am about to beat this bumper back into shape and hurculiner it with the front winch bumper so they will match when I install them.
When I was under the bronco I realized the brackets that attach it to the frame are not very long at all. Maybe a few inches where it overlaps the frame and then the spring perch is right there.
Can I even install this bumper without modifying it first? Look how long the mounting brackets are. It came off a obs pick-up.
It's going to suck cutting those with a grinder. Anyone in Dallas have a plasma cutter I can come over and use???
Here is a pic to give you an ideal.
I put arrows where it bolts up. You can see where the back edge of the bumper is, bracket comes out only a few inches and attaches to the frame and pretty much almost already touches the spring hanger. I don't think I have a choice but to cut it or herculiner the bumper on it now.
On a truck would not be an issue since the spring hangers are not so close to the rear but it looks like on the broncos you need to have a short bracket set-up for it to not hit the spring hanger.
brokersteve
11-02-2012 05:18 AM
buckshot1822
07-25-2010 11:06 AM
scottw383
07-20-2006 02:04 PM
