I had the motor off the other day and could hear the blower motor for the heater is only on when the fan speed is on high. Does anyone know what area I should look at for this? Will this be a problem with the blower motor or the fan speed switch?
Yep.. you have the classic blower motor resistor problem, sometimes the resistor pack is burnt out but other times corrosion on the connectors is the problem.
