Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
Closed Thread
  #16 (permalink)
Old 11-16-2004, 01:19 PM
mwkatm mwkatm is offline
mwkatm is starting off with a positive reputation.
Question MAF Cleaning
Racerguy,
In my 98 F-150 4.6L, do I have to remove the MAF before cleaning, or is it possible to just open the airbox, move the filter, and zap it in the tube? Will the cleaner evaporate, or will it hang around in the intake tube? I just put a K&N filter in and I was going to clean my MAF after a thousand miles or so to make sure that some oil didn't get on it. I beleive that since putting my K&N filter in (and making a poor man's CAI), and installing a Flowmaster 40 series muffler with a single 3" out, my gas mileage actually did go up, I am excited about that. But, I have heard of some folks losing some milage and performance after dropping in oiled-type air filters due to gumming of the MAF.
Thanks for your time.
mwkatm
  #17 (permalink)
Old 11-16-2004, 01:27 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold Racerguy is a splendid one to behold
Hi and welcome to the forum
To clean the MAF you just open up the airbox and it's right there like in the picture above. The cleaner will evaporate but sometimes a bit gets into the intake tube. It's no big deal.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #18 (permalink)
Old 12-31-2004, 07:33 PM
Red 97 Red 97 is offline
Red 97 is starting off with a positive reputation.
racerguy
I own a 1997 f150w4.6 2wd extended cab ,auto ,lariet
It has the pinging problem that seems to be pretty common. Did the tune up ,maf ect.
no help , I was told of an octane bar (spout connector) under the hood,was told to unplug it & the timing should retard 2-3 degrees ,have you heard of this? & where is this thanks in advance.Guy
  #19 (permalink)
Old 12-31-2004, 08:17 PM
Racerguy's Avatar
It should be near the starter solenoid etc, possibly under the black plastic cover, near the battery. It's a squarish plug that's plugged into a connector with Grey/Red and Dark Green wires going to it.
__________________
Forum Guidelines
this space for rent
  #20 (permalink)
Old 03-26-2005, 02:21 PM
ffin90's Avatar
ffin90 ffin90 is offline
ffin90 is starting off with a positive reputation.
Forum newbie, IAC ?
First time testing the forum waters. This is great, I found the probable cause to my cold starting ( Idling problem ) I think. Would this IAC also cause any gas consumption problems?, since the starting problem started my truck has been sucking back gas like it's 10 cents a litre and it's never been this bad.
  #21 (permalink)
Old 03-26-2005, 02:25 PM
Racerguy's Avatar
Welcome aboard
An IAC problem shouldn't cause the truck to burn too much gas usually.
How many miles on it? How old are your spark plugs? Fuel filter? Air filter?
__________________
Forum Guidelines
this space for rent
  #22 (permalink)
Old 08-16-2005, 04:51 PM
RMbros RMbros is offline
RMbros is starting off with a positive reputation.
Hey all, just posted a new thread about this, but I figured that that would disappear pretty soon.
Here was the post:
I've just been searching for 7-lug wheels for my 99 F250 LD Screw and stumbled across another option - Jesse James Wheels.
http://www.jessejameswheels.com/
Look at the .50s they're the only ones that I saw lug patterns for.
To expensive for me, but some of y'all might not have the same handicap.
Also heard that Centerline might be able to drill out one model, but I can't find any evidence.
  #23 (permalink)
Old 08-17-2005, 09:59 PM
One other 7-lug for F-250LD - Ultra Wheels Ultra 164s, but only in 16s
  #24 (permalink)
Old 03-26-2006, 09:39 AM
peppermrj's Avatar
peppermrj peppermrj is offline
peppermrj is starting off with a positive reputation.
How to replace your DPFE sensor
Unplug the plug.
Mark the two vacuum lines front and rear.
Unbolt.
Remove.
Installation is the reverse.
Additions, deletions, corrections?
  #25 (permalink)
Old 03-26-2006, 10:46 AM
Racerguy's Avatar
Looks good to me
Thanks
__________________
Forum Guidelines
this space for rent
  #26 (permalink)
Old 05-06-2006, 08:36 PM
rpogue rpogue is offline
rpogue is starting off with a positive reputation.
I have a '98 5.4L - I've seen several comments in several places about the 'door ajar/wd40' issue. While I agree that there's an issue, I think your solution may be only partially correct. When we got the truck, about 3 years and 40,000 miles ago, the 'door ajar' light, the 'ding-ding', the dome light - all harassed us on a regular basis. Most of the time they’d stop before you’d gone too far, but my wife finally took the dome light out, to prevent draining the battery. We’d taken it back to the dealer, squirted wd40 in the door latch – tried ‘em all.
Then – about 18 months ago, preparing for a trip to Texas, she took it to the local “Rapid Lube”, and the guy offered to fix the problem. She laughed and told him to go ahead – knowing the history. He squirted wd40 into the Ignition Switch!! Issue resolved.
  #27 (permalink)
Old 07-04-2006, 12:23 AM
triton54's Avatar
triton54 triton54 is offline
triton54 is starting off with a positive reputation.
the tonneau cover theory, mythbusters busted that one. no drag is created actually the air swirls in the bed and lets passing air flow over the bad and tailgate as if there was an invisible cover. tonneau is a waste of money if u want to prevent drag. drag dont exist.
  #28 (permalink)
Old 07-14-2006, 06:28 PM
Munky's Avatar
Munky Munky is offline
Munky is starting off with a positive reputation.
I've been reading a lot on these forums about the gears in the rear end, whether it's 3.55 or whatever. I'm wondering, how do I find out what gears my truck has in it?
__________________
Owner of a 2000 Ford F-150 XL Sport 4x4 w/ 4.6L V8
  #29 (permalink)
Old 07-15-2006, 12:48 PM
Racerguy's Avatar
Munky there is a tag on the rear end that will say what the ratio is or you can look at the Vehicle Certification Label on the door post. There's a code there under Axle. The common codes are 19 — 3.55 non-limited slip, 18 — 3.08 non-limited slip, H9 — 3.55 limited slip, B6 — 3.73 limited slip.
__________________
Forum Guidelines
this space for rent
  #30 (permalink)
Old 09-02-2006, 02:34 AM
Chris 97 F150 Chris 97 F150 is offline
Chris 97 F150 is starting off with a positive reputation.
Help ASAP (Stalling)
I have a 1997 F-150, V8, 4.6L, 4x4, unknown milage
I was reading through the FAQs about the IAC valve... i bought my truck about 2 months ago with the motor locked up...My dad and I put in a rebuilt motor in it ourselves...everything seemed fine and all, but there was just one problem...sometimes I will have to make a stop at a stoplight, stopsign, or even sometimes making a slow turn, and my truck would stall (gets down to about 200-300 rpms...until it stalls) then I have to restart it and go on again...and sometimes it doesnt stall, it just seems like it will, but it idles back higher to keep it from stalling...but it just idles perfectly and dandy when in park or neutral (with about 600-700 rpms)......i practically have to have the pedal pushed in a little bit for it to keep a high enough idle for it not to stall...would this be a HIGH POSSIBILITY that the IAC valve is faulty?
over the past month of frustratingally working on my truck and tryin to figure out why my truck is stalling, weve tested my truck with a modis to look for codes, couldnt see anything with the IAC...but does that mean anything, maybe hard to diagnose? i have no idea what it could be, but another sensor that came to my mind was the camshaft position sensor...sounds more like the symptoms of IAC as ive read in previous posts
Im so confused and frustrated with this, so please, i need alotta help!
Closed Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
