No start without starting fluid
My 2000 4.2 will not start without start fluid! New fuel filter. I can hear the pump activate with key in on position. Checked all fuses..At one point it would start after 3 cranks pausing to hear pump in-between cranks. Now I have to use start fluid. It will run fine after starting...Help!!
I am not familiar enough with that motor to be much help, but your symptoms as described point to either weak spark or low compression. The starting fluid is making the fuel air mix more volatile and easier to ignite. Once there is fire, the residual heat helps the ignition process. Does the motor idle normally?
Everything works fine after start up..
ALL BOY
08-17-2011 01:09 AM
barrier
01-12-2011 04:53 PM
Knox
16
11-01-2009 10:37 AM
