The 130 amp alternator (generator) is stock on the 1994 460 with the F53 chassis.
I know I have one.
Just buy one for the 1994 F53.
Rockauto PURE ENERGY 15888N 130 amp alt.
The one from rock auto 15888N is the wrong one for my truck. The mounting holes are about 8 1/2 inches mine is about 7 inches. I'll have to return that one. Any other suggestions?
Lester interchange 7765.
7" c-c 130A is an application for a 1993 3.0l Taurus/Sable
I posted a link above.
Second, I can never remember what displacement is the correct one, so I just go for the pushrod motor. Be warned, the alt is clocked differently. You can take it apart and rotate it, but as it comes the wiring will be at the bottom of the alt once it's installed.
3.0l is 7"
3.8l is 8.25"
1993 seems to be the year for both.
I have a 3.8 alternator in my V-belt truck.
Be careful when clocking..
You only want to crack the case far enough to clear the locating tabs.
I thought the 1G & 2G alternators were gone by then.
No one is seeing your spam posts buddy.
Goodbye!
1G's were around in diesels quite late.
2G's problems were finally addressed by Ford's TSB 96214 (Feb 14th 1996)
So it was still an issue at that date.
