Hi mileage 6.7s
I have an '11 6.7 with 182K on the clock and the thing is an animal. I absolutely love the truck. just take care of it. pay attention to it. its a solid rig. but like any other mechanical device, it can break. if you pay attention to the warning signs, sounds, DTC codes, etc. and keep up with the maintenance, i assure you you will get many years and miles of reliable service from it.
and, IMHO, the '11-'14s are the ones to get if your looking at used. my cousin has had 4 of them, 2 were '15s, and he said you'll get 250K with no issue on the '11 - '14 models, '15 and up had issues with the turbos.
dont know what else to say other than mine is rock solid and running like new (i just drove a brand new one a week ago) and it has 182K on it.
Cheers.
Jay.
Cheers.
Jay.
Have there been problems with SOME 6.7s? Yes, a very very small number (probably equal to those from a Cummins engine)
How do they do with over 100k miles? Great, for those who have maintained them. I'm sure some will say they have had issues.
2011 vs 2016: the 2016 is the better engine just due to the advancements made as a gen 2 power plant. The 2011-2014 is a great engine also. Common sense would dictate that you try to find one that is a year after initial production.
Hope this helps.
Well, failure of the turbo ceramic bearings on the first generation were well noted, but I have not heard of any problems with the gen-2 turbo on the 15+ models. That info provided seems backwards.
Received 1,446 Likes
on
Here's an early build 6.7 with 506k miles. If I remember correctly all that was replaced on the truck was the water pump.
https://www.youtube.com/watch?v=D3Mf...ature=youtu.be
Did the c/c models use the ceramic bearings too? I know it was a different turbo. Uncle has an F-550 dump, 2011, 6.7L. No engine issues except sensors.
