1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cracked Front End Part
Old 01-03-2016, 12:17 PM
Kongerup's Avatar
Kongerup
Kongerup is offline
I was just in the middle of doing the V Code leaf spring swap and noticed a broke part where the u-bolts sit and what looks to be attached to the trac bar. The piece is broken in half and I am not sure how this happened or when. Looking for advice on how to repair. The piece is welded to the axle.
2003 Excursion 4x4 6.0
Old 01-03-2016, 12:26 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
First off, how about giving some info about your truck. Year, model and anything else you think might help someone give assistance on resolving your problem.
Old 01-03-2016, 12:28 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
that's not good. do you have larger tires on or do a lot of offroading? The stress of either of these could have caused the failure. I would get that fixed ASAP, looks like you'll have to cut the old bracket off and weld a new one on. A good weld shop might also be able to fix the existing bracket and reinforce it.
I'm guessing since it has leafs it an '04 or older.
Old 01-03-2016, 12:41 PM
Kongerup's Avatar
Kongerup
Kongerup is offline
My apologies, should have included that in initial post.
Old 01-03-2016, 12:44 PM
Kongerup's Avatar
Kongerup
Kongerup is offline
No, running 275/70/18 tires and have not had the truck off-road. I have only owned it for 1 year. Either it was broken when I bought it or the only thing I can think of is when my wife was driving, she hit a curb going pretty fast. Didn't notice any major handling difference after she hit it.
Old 01-03-2016, 01:32 PM
redford's Avatar
redford
redford is online now
Received 1,550 Likes on 905 Posts
It does appear that it has been cracked for a while, not recent at all.
Old 01-03-2016, 01:50 PM
Tom's Avatar
Tom
Tom is online now
I'd definitely take that to a welding shop for evaluation, I bet that can be repaired.
Sparky83
North Carolina Chapter
24
09-18-2019 02:43 AM
Kongerup
01-04-2016 12:27 PM
USCG_PA
01-24-2014 09:37 PM
alpha/omega
Offroad & 4x4
365
10-14-2013 02:13 PM
snaponprofile
33
02-07-2012 01:29 AM
Quick Reply: Cracked Front End Part
