Help leveling/lifting 03 E350 Extended
Okay I am new to the site and don't really know where to ask but i read this so i figured to reply to this.
I have a 2003 E350 extended. just want the front a little higher to fit bigger tires.
I currently have toyo AT2's and they are amazing in the size of 245/75/16 (stock)
Last time I tried, 265's didn't quite fit. thats all I really want. I was going to buy new springs from sdtrucksprings.com ...the part number for this van is TTC-2814.
I wasn't sure if maybe these would be higher in general or because mine could be warn and also possibly because these are stronger they won't push down as far when installed. Same thing with the rear, not to lift, but if i bought 6/1 leaf springs from the same website, part number 43-1041HD, wouldn't that push up the rear because there is more curve? Any one know the answer? One more question...
With this twin I beam setup, you can't to a suspension lift without changing those to the ones that are bent? correct? and there is only a few companies that sell a suspension lift for it correct?
1. I'm into cars and know a decent amount but I'm not understanding why the stock I beams won't work, Explain?
2. Can you do a body lift with the stock I beams? I've seen to be able to find one website that sells 2" coil spacers but will not buy if I its going to mess up the I beams or not work or wear my tires terribly. Anyone can text me for help if you would like, I'm on the go a lot. 2077521336
DAVID WERTZ
11-06-2018 12:24 PM
E-350 EXT.
01-03-2016 09:17 AM
ProWrench
07-19-2009 03:09 PM
handmedownf150
10-08-2006 09:00 AM
