2004 Ford F-150 need to mess with column shifter to start
Old 01-02-2016, 04:28 PM
A.Rod5827's Avatar
A.Rod5827
A.Rod5827 is offline
Hello I'm having trouble with my 2004 Ford F-150 5.4 Triton V8 starting, when i try to start it i have to move the shifter all the way down and up multiple times with the key open in order to start the truck. I don't what it is I think it may be the Neutral Safety Switch or Shifter cable.
Old 01-02-2016, 07:34 PM
milliesdad's Avatar
milliesdad
milliesdad is offline
Sounds like neutral safety switch or possible ign switch.
Old 01-03-2016, 12:29 AM
brokenleg's Avatar
brokenleg
brokenleg is offline
I bet its the range switch on the transmission.
Old 01-03-2016, 03:57 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Bet it's none of the above if the shift lever is "sloppy", the most common situation.
It's probably either loose Torx-headed bolts in the shift cable bracket or worn out shift tube bushings. Those account for over 90% of these symptoms.
Ford hasn't used a neutral safety switch on their automatics for over 25 years, since they went to electrically controlled transmissions. That interlock has been built into the sensor mounted on the transmission that reports the position of the shifter.
96firephoenix
03-13-2018 09:14 AM
Lost_in_tx
12-21-2016 09:30 AM
Runningmanf250
02-19-2008 03:19 AM
75FullsizeRanger
12-12-2003 07:26 PM
olyellr
06-16-2002 01:18 PM
Quick Reply: 2004 Ford F-150 need to mess with column shifter to start
