55 F-250 Stock rim and tire size
Old 01-02-2016, 11:11 AM
jaskoskip's Avatar
jaskoskip
jaskoskip is offline
Im trying to put stock wheels on my 55 F-250 and I'm having a hard time trying to find out the stock rim and tire size for the F-250. I know that the F-100 had 16x4.5 in rims but does the f-250 have the same dimensions or is it because it's a heavier duty truck it had wider rims.
Thanks.
Old 01-02-2016, 01:45 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
I tried to give the answer to this question in post #6 of this thread. Yes, the F-250 rims were wider, 6.00" vs 4.50", and have stronger 8 bolt pattern, to handle the added load capacity. Stu
https://www.ford-trucks.com/forums/1...xle-ratio.html
Old 01-02-2016, 01:55 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,440 Likes on 1,390 Posts
According to the Ford parts catalog, 55 F250's used a 16x6 rim with 6.50, 7.00 or 7.50x16 tires, or a 17" 2 piece rim with 7.00 and 7.50x17" tires. The catalog does not identify the width of that rim.
Old 01-02-2016, 02:01 PM
truckdog62563
The 17" x 5.5" wheel is the widow maker Budd 49380 having the Firestone RH-5° outer rim. I didn't mention these because they aren't a sensible option today. Mentally I sped right past the widow maker in the earlier post because of the 28" tire size. The 17" would be 34" tall, so it was clear the truck has the 16" set. Stu
sowa1955
07-28-2017 03:10 AM
Trainhound
07-05-2012 09:25 AM
dimreality22
12-27-2008 03:17 PM
Fishsimion
09-10-2006 06:03 PM
mike9762
03-01-2005 07:02 PM
Quick Reply: 55 F-250 Stock rim and tire size
