Here is how I fabricate my tailgate hinges using the Pro's Pick hiding hinges. Once painted the hinges are almost completely hidden by the tailgate. The rear sill in this photo is a length of .125 wall 2x4 rectangular stock...I like to keep it clean.
Very nice Charlie, I fabricated this same idea out of my head this afternoon, I may have made them larger and will scale them down to look more like yours as they will defiantly hide/blend in with the painted body colour!
Man, I've bought so many latches. I tried the hidden thumb latches, and none of them seem to go far enough through the sheet metal to provide a sturdy hold. An 89.00 expense I didnt seem to like. Then I ordered the same latches that Bill has on his red truck above. $125.00 from MF. I hated the fact that Id have to drill through the side of the body and have visible nuts on the outside of the bed. I tried and tried to find something that could be bolted in place and wouldnt show through.
I finally found these hinges with a removable pin Heavy Duty Hatch Hinge ? Standard | Unicorn Stainless
and these nice pins from eBay 5 16" x 1 1 2" Grip 17 4 Stainless Avibank Ball Lock Quick Release Pin T Hdl | eBay
Worked perfectly! Pull a pin on each side and drop the tailgate
The hinges that you installed are also a marine product (316ss) like the catches that I used. I have the same basic hinges on my boat for a deck hatch.
Looks good!
