3.73 or 4.30 gears?
#31
#32
#33
3.73 or 4.30 gears?
I've got 4.30 gears and love them
2002 F350 Dually, V10 six speed, regular cab XL (pretty well stripped down truck)
Honestly, 6th gear is so tall that i dont use it to accelerate on big hills
I really wouldn't want a taller top gear.
And on top of that, I'm actually running a whipple supercharger and a set of shortie headers on it right now..... and a cat back exhaust.
Even without the blower, it moved along pretty good for a big truck
#34
#35
3.73 or 4.30 gears?
Originally posted by WyoShane
Does the V-10 get stronger with milage? I have a 2003 3/4 4X4 with 3.73 gears and when I pull my lightweight (around 4000 lbs) travel trailer I'm having to go into 2nd gear to stay going 60 - 65 mph up a decent hill.
Not that much stronger. I found out the same thing when I pull a similar camper up to Eisenhower tunnel. I take it you are in Wyo and the thing that kills us is losing about 25 to 30% of the HP at 10,000 ft plus grades.
I was disappointed at first but reading at this site people have explained that the V-10 is not like your dad's V-8. You can run it at a lot higher RPM. So the last time I pulled my trailer over Eishenhower grade I did what another guy told me to and locked it in 2nd and was pulling around 4,000rpm doing 60 or so MPH and passing lots of cars and trucks. Not even close to full throttle or max rpm. Averaged 12.5mpg to Steamboat Lake and back. Anyway, I'm glad i didn't get the 5.4L. My buddies SC 250 with a 5.4L and 4.10 gears searches between 2nd and 3rd on the same grade without a trailer.
#36
3.73 or 4.30 gears?
V104Me, Yes everything is still stock as of now. Actually I’m usually running around 70 in Drive and am turning at least 2300 rpm’s. It seems like that when I see a hill coming if I help out the cruise control and help keep the rpm’s up it will keep it’s power a little better up the hill. But if I don’t do it just right then the power drops right down and I end up having to go to 2nd to keep it at 60 to 65. Right now I’m deciding what to do – gear swap, exhaust change or different truck.
#37
3.73 or 4.30 gears?
If you have 3.73 diffs with an auto and stock 265's you should be turning around 2800rpm at 70 mph in drive, about 2000rpm at 70 in OD. I think some trucks came with 235 tires which look way to small. If they were changed to 265s maybe you would be turning 2300rpm in drive at 70mph.
#38
