2002 Explorer sport trac draw
Working on my brother's 02 Sport trac with a parasitic draw. I fulled individually pulled the under-hood fuses and no change. I started pulling the interior fuses and when I pull fuse 26 - interior lights/ battery saver the amp draw dropped to an acceptable level. Any ideas how to fix the issue?
The light in the glovebox maybe something worth looking into. When I bought my 2002 in early 2015 I noticed the bulb in the glove box was missing. I installed a new bulb and found it was not turning off when I shut the glove box door. Until I can get around to it I don't have a bulb in there for the time being.
Also, is the dashboard dimmer switch going wild at the slightest touch or movement? If so that could be bad and possibly something inside of it may be arcing ever so slightly inside of it.
Read the thread below (read the whole thing). If there's a chance of a fire then there's going to a draw before that fire starts. This was about the recall that was for various models of the Explorer in the late 90s and early 2000s. Call your dealership's service department to run the VIN to check if yours has had that harness replaced, yet (if you don't already know if it has or not).
https://www.explorerforum.com/forums...d.php?t=262765
joeimp
Electrical Systems/Wiring
01-15-2018 07:33 AM
geo
08-24-2000 02:53 PM
