Hey guys it's been a while since I've been on here since I started a new job. I need some help from my favorite forum. No matter what I do with the settings for my heater in my lariat air only blows out of the dash vents. Defrost and floor vents don't work it still blows hot air out of the dash vents. I'm not sure what the deal is maybe the vacuum system? I did a search and all I could find was people having trouble with air ONLY blowing out of the defroster and my case is just the opposite.
Based on prior experience, it could be a vacuum issue. I would also venture to say that your locking hubs won't work either since they are vacuum operated. Had this problem in an older Ford pickup.
It does have dual climate control. I'm not sure about the locking hubs yet since I haven't had to put it 4x4 this year. What are the symptoms if the hubs ain't locking?
I switched between 4x4 and 2wd I can hear my hubs locking (or a sound that makes me think they are locking) but no change in ventilation in the cab. Would the blend door have anything to do with this issue I'm having? I do notice that once the cab is heated then the system blows out cooler air until I turn up the temp a few degrees when the system is on auto
My understanding is the currant gen trucks are actuating blend doors electronically via stepper motors, not vacuum. I think running codes is a good first step.
I think my scanner will read it (mines an XLT, but I'll check sometime this weekend to confirm) if you want to meet up.
Hey guys it's been a while since I've been on here since I started a new job. I need some help from my favorite forum. No matter what I do with the settings for my heater in my lariat air only blows out of the dash vents...
Welcome back, Blapensee! I'd recommend having the truck diagnosed by your local Ford Dealer; I'm sure they'd be happy to solve this vent mystery for you. How many miles are on your rig?
