Brakes on 2000 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-08-2003, 02:46 AM
vfrocket's Avatar
vfrocket vfrocket is offline
vfrocket is starting off with a positive reputation.
I have a 2000 Ranger 3.0 l V6 Flex fuel, ABS on rear, and 92,000 miles on it. I changed the brakes once before on the front @ 50,000 miles, I put new pads and rotors on it, and repacked the bearing etc....
now I am experiencening shaking breaks when I stop, it is very obvious the rotors are warped. Any way I have noticed the passenger wheel has alot more brake dust on it than the driver side. What could be causing this? perhaps one of the calipers? I'm not sure how to tell, and can this be adjusted? I have heard of people having to put "Brake Freeze" lubricant on the calipers or somthing like that....
Any way. this weekend I am planing to put new pads and rotors on it again, and I would appriciate your suggenstions...
Thanks
Old 08-08-2003, 08:13 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Check the slider on the brake caliber and make sure it isn't sticking. You can not use regular brake grease on the newer rangers. Ford has some weird organic grease they use on the caliber bolts. This bolt has a rubber boot on it. You have to go to ford and buy the bolt. It comes with this special grease.
Brake dust is normal. Soft brake pads cause a lot of brake dust. Keep your wheels well waxed and the dust won't stick to them.
Old 08-08-2003, 08:50 AM
PSKSAM2's Avatar
PSKSAM2 PSKSAM2 is offline
PSKSAM2 is gaining momentum as a positive member of FTE.PSKSAM2 is gaining momentum as a positive member of FTE.
You have to go to Ford for that caliper pin/bolt now? I got them at Autozone for $9 for both sides for my '98.
Old 08-08-2003, 08:58 AM
WXboy's Avatar
WXboy WXboy is offline
WXboy is starting off with a positive reputation.
Also, don't buy cheap rotors. It's possible that aftermarket rotors could warp faster than the factory rotors.
Old 08-08-2003, 09:41 AM
I don't know. I am taking this info out of the ford manual. FOrd claims that there is no substitute for their grease. It is possible the autoparts places are now selling it.
Quote:
Old 08-09-2003, 01:35 AM
vfrocket's Avatar
Thanks for the info guys.... Do you think I need to replace the calipers, or just get the special grease from Ford? Do you apply the grease to the two bolts that hold the caliper on???
Anyway thanks for the replys....
P.S. this 2000 Ranger is the BEST truck I have ever owned....
Best brake pads Irelands child 1999 to 2016 Super Duty 22 07-17-2016 01:45 PM
Stuck caliper questions kitebuz Excursion - King of SUVs 2 07-02-2014 11:29 AM
Smoking rear brake - caliper frozen dogerbrown1 1999 to 2016 Super Duty 1 10-24-2011 12:31 AM
QUESTION ON FRONT BRAKES TO CORRECT PROBLEM... edster 1999 to 2016 Super Duty 1 08-21-2010 10:39 PM
brake clatter aggrevation first today 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 12-07-2009 10:21 PM
Tags
1997, brake, caliper, ford, grease, lubricant, pin, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
