Repro sport bumpers... Created equal?
The chrome contour bumper that is. Looking at ordering one for Bruce, my '77, when Uncle Sam pays back the money I loaned him this year. I see LMC, JBG and I believe Dennis Carpenter has them as well. Is one just as good as the other? I was planning to modify bronco brackets to fit
Whomever bumper you do decide to buy, rustproof the back side with a finish. Even nth degree show cars have crummy chroming on the back side because no one sees it.
I used Rust Encapsulator, scuffed, and laid on a gloss coat of black rustoleum... plus it's easier to hose off dirt and grit from a glossy surface than a rough surface.
X2 on HIO advice. And you get what you pay for, meaning spend the coin and get quality parts. So I vote for DC, not LMC.
The contour mount brackets are the hard part to find. I mean real hard, since they are not reproduced by any vendor. But there is a FTE member in the beginning stages of reproducing them.
You can get a bolt on receiver hitch to work with the contour bumper.
Thanks for the advice Hio, will do. Local junkyard has a bronco with the bumper and brackets so I should be good there. Yes I know I'll have to lengthen them but I figure they will be a good start.
Price isn't really an issue because lmc, dc, bronco graveyard are all in the same price range.
I have a set of Dean's sport bumper brackets, and they are beautifully made. He modified them to provide more adjustment than the factory originals, you can really snug the bumper right under the tailgate so that there isn't such a gap.
https://www.ford-trucks.com/forums/1...-brackets.html
David
David
There are TWO DIFFERENT types of contour rear bumpers ('sport bumper' is an LMC "invention.")
One is used with 33 1/2" frame rails (1964/72 F100/350; 1973/77 F250 4WD & 1973/79 F350), t'other with 37 1/2" frame rails (everything else inc. 1978/79 Bronco).
Upper pic:
David
David
Below are the common Bronco brackets.... the left is modified and the right one is stock. They, including the outboard brackets, will need to be extended and then drilled to space the bumper from the trailing edge of the fenders. Use 2-inch wide, 3/16th-inch plate.
