2014 F450 Front end shakes when breaking hard/towing
2014 F450. Front end and steering wheel shake violently when braking while towing a 20,000 pound trailer down a long and steep highway grade. It does not happen when towing my 12,000 pound trailer down the same highway. Could I be setting off the ABS braking system?
you are over the max trailer towing limit for a 2014 f-450. whats your tounge weight and have you checked on how to adjust your trailer brake controller.....it obviusly should have a different setting for the two different trailers.
http://www.ford.com/resources/ford/g...typu_sep11.pdf
Trailer brakes are working well and set at maximum. I wonder if the Stock Ford Brake Controller is the problem?
When you step on the brakes, does it feel like the truck dives?
I just feel like all your weight is being shifted to the front axle for whatever reason.
Or that the front end suspension isn't up to the load for some reason, such as ball joints or tie rod ends that are normally ok, but are overwhelmed in that particular situation.
I took the truck to a Ford dealer for service about 4 months ago and told them to check the rotors and front end. They said everything was OK. I guess I will have to take it back to Ford so they can have another look. This issue never happened with my previous Ford trucks while hauling the same trailer.
Crystal
I took the truck to Ford for service and for them to check out the front end shaking issue. They could not find anything wrong. Last weekend I drove the truck and trailer over the very steep grapevine and it shook violently when applying the brakes while going down hill. The front end is also violently shaking at times without the trailer. I am looking for streets near the Ford service center where I can recreate the shaking so I can take one of their service managers for a ride.
