Ontarios 2016 January to December thread
#2491
Received 5,128 Likes
on
Yes just a gasket, clean is your friend,
clean out the pan & use clean tools on the filter, 5/16ths
when you drop the filter screws there is ONE bolt longer than the others, (at the back)
make sure it goes back in the same hole.
its only aluminum so dont over torque anything,
do you have an inch pound torque wrench ....
if not just use common sense
#2492
Received 4,112 Likes
on
#2493
on
the pan gasket should come with the filter,
theres also a gasket under/above the filter .....
it should be complete .........
read this
Bolt Installation & Torque Specs C6 Remanufactured Valve Body C6 ...
read this
#2494
on
#2495
on
I just wanted to show you where the long bolt goes & the torque,
QUOTE: Install valve body to case bolts. Torque bolts to 50 in-lbs
I'm sure you'll be fine ....... ignore the rest
if you get the cork pan gasket, clean the 2 surfaces good & dry,
then put the pan gasket on dry as well, dont over tighten the pan bolts
NO silicone or anything
#2496
#2497
on
#2498
on
#2500
on
#2503
on
Nice Work Truck
Connecticut Chapter
297
02-02-2014 09:16 PM
SpringerPop
S. California Chapter
94
01-31-2014 11:08 PM
