93 5.8 misfiring under load - hoping for quick diagnosis
I'll take a closer look but I think this Boise van has only one cat post collector.
FWIW rerouting the starboard side plug wires around the cabin heat riser seems to have done the trick. A couple of trips to 4000' with half the seats occupied and no misfiring. I'll try the underhood borealis when I find a water spritzer.
Sixto
93 E150 Chateau 5.8 193K miles
Sixto
Unburnt fuel hitting the CAT's from a misfire will very quickly destroy the front of the converter with the exploding unburned fuel.... Been there done that in literally 20 miles.
It's possible that the upstream cat plugs without collapsing into the downstream cat, but I've never seen it.
I could be barking up a wrong tree but I've seen it time and time again on our vehicles. Steady misfire on bank 2 cylinders. Reduced power, problems at full throttle, sometimes even a clanging sound in time with RPM that makes you think you've got serious engine issues. It might start gradually with just a couple misfires now and then and grow.
Originally Posted by delgriffith
No, The upstream cat collapses and plugs up the downstream cat. You can pull the upstream sensor to breath but you loose the ability to set mixture properly when you pull the upstream sensor. Pulling the downstream sensor will bypass the blockage at the downstream cat and still allow proper mixture setting since the downstream sensor is just there for fun.
Still has a misfire but that has been positively linked to a clogged injector, there is also an intermittent stumble but that is the result of the ECU having an intermittent 'brain fart' and is what i consider as normal for these vehicles because of the limited processing power that was available when these ECU's were designed and built..
When diagnosing a misfire or stumble you need to take all these factors into account and rarely is it ever as simple as replacing plugs or wires, ..
my van had a cat so clogged, the backpressure broke the pass side exhaust manifold (single exhaust van), literally busted the manifold. Covered engine bay with black greasy exhaust fumes all over everything, this is from the prior owner, I have about everything sorted now. When the cat came off, it was like lava rocks coming out of it by the handfuls.
BAD351W
05-16-2009 09:10 AM
