Using 4WD question
Using 4WD question
Is there any harm at low speeds (<30mph or so) frequently switching between 2wd and 4wd? Had our first snow this AM and the first part of my commute is hilly, then a flat section which is well plowed, then a hilly part. In the past (pre-F250 days when I drove a Subaru clad w dedicated snow tires), the first and last parts of my commute were generally poorly plowed and hilly while the middle part often was bare pavement.
And these truck have alot more inertia than a Forrester!
I shift back and forth all the time with no issue. Snow patches are pretty common a few days after the main event. I just ran 2WD the whole day yesterday, for the first time in a while.
When I'm in 4X4, I know I can go much faster, but I top out at about 50 on the long stretches. If I need 4X4 to accelerate and stay straight on the road, then I know my stopping distance and control isn't going to be up to par. I don't want to get myself into something I can't get out of.
Received 3,106 Likes
on
when it is slick outside, i leave the front hubs locked and the t-case in 2 wheel .then when i need 4 wheel drive i just let off the throttle and pull the shifter into 4 wheel. once back on clean road i let off again and kick the shifter back into 2 wheel. the plow trucks always have the front hubs locked.
Am I correct to assume that you guys are shifting a manual transfer case between 4/2wd while traveling at speed on the road?
I was under the impression that shifting a manual transfer case between 2/4wd should only happen while the vehicle is stationary and not moving.
Obviously the front hubs are locked, which would keep the front and rear driveshafts spinning at the same speed. It's new information to me if you guys are indeed shifting from 2wd to 4wd at driving speeds. I've shifted from 4wd to 2wd at speeds of 5mph and less, without issue -- but doing so while travelling at 30mph... I didn't know you could do that and never wanted to try for fear of breaking things.
My understanding is that my truck has ESOF (Electronic Shift on The Fly) 4WD and that it is safe to hit the switch at any speed as long as no wheel is spinning. When they say, "no wheel is spinning", they mean faster than any other wheel(s) or lost traction. I would hope that I would never end up in a situation where I'd have to do that at high speeds but If I had to I would. Would that be a mistake?
on
