Waters in the wiring channel on the passenger side..
Old 12-31-2015, 09:31 PM
MR KROGOTH's Avatar
MR KROGOTH
MR KROGOTH is offline
Originally Posted by ArdWrknTrk
Whatever you say...
There's a paint and bodywork subforum here on FTE.
Plenty of full time body guys more than willing to share their passion.
Gonna quote from the other leak thread:
It is not just caulk. It's seam sealer.
Our shop uses 3M products,
For seam sealer we use 3M 8361 - Urethane Seam Sealer (grey).
To apply that product you'll need a 3M applicator, the 3M 8398.
If memory serves me right (It's been awhile, forgive me) I believe I've used 3M 8362 Urethane Seam Sealer in a regular old caulk gun. I was like 16-17 years old then. the 8362 is the same product as the 8361 just in a different package. It's rated for external use, and you can slather than sludge everywhere, I had to do it to get my dads '97 F350 from leaking.
You could (read: probably shouldn't) use 3M 8307 Self Leveling Seam Sealer for that as well, but it may not take as well as the 8361 and you'd need a 3M 8117 or similar to apply it.
If you decide to get the 8117 applicator, there's a myriad of 3M products out there you can use it with - namely 8115 Panel Bonding Adhesive. Mix it with fiberglass flox and you'd be surprised what you can fix.
Good luck.
I can and will tell you run fast and run far from silicone caulk. There's a right way and wrong way to do it, the seam sealer Ford used lasted this long, why not go back with what came off?
Also upon looking at your pictures of the leak, I'm almost tempted to say it's leaking at the rear window seal and not the body seam. Not there to judge and inspect it so YMMV.
Old 01-01-2016, 12:25 AM
simonwim's Avatar
simonwim
simonwim is offline
Awesome info, thanks. I'll maybe double check things tomorrow and take it from there happy new year
Old 01-01-2016, 03:53 PM
dixie460's Avatar
dixie460
dixie460 is offline
For what it's worth, before I knew any better I used clear silly-cone and it did NOT like being painted over one bit! Had to use a wire wheel to get it all out. What a mess.
Old 01-01-2016, 03:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
NEVER silicone!
It won't hold and paint will never stick.
I use a single component urethane but there are plenty of body sealant caulks available.
Agreed. But there is no need for urethane on a rubber gasket.
Remove the rear window, seam seal the seams, let dry and reinstall the window
Old 01-01-2016, 07:46 PM
MR KROGOTH's Avatar
MR KROGOTH
It's the bane of body shop existence.
I remember when I first began working in this shop, and the owners had also hired a new mechanic who had never operated in a collision repair facility. Cracked open a tube of RTV and went to sealing something (IIRC it was a '69 Firebird rear end we were rebuilding!) When the painter ran out of the booth to slap it out of his hands and throw it out of the shop. I walked into the booth just in time to watch paint he had just sprayed on half a car literally run off the body like oil on water. Never again did we allow Silicone in the shop!
Old 01-01-2016, 08:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I wasn't talking about the window seal Brad.
I was talking about the rain gutter and the seam running TO the rear window opening.
Old 01-12-2016, 10:58 AM
simonwim's Avatar
simonwim
simonwim is offline
I ran a bead of clear silicon along the bottom of the window and it seems to have cured the leak
Old 11-06-2019, 01:55 PM
F2501972's Avatar
F2501972
F2501972 is offline
Hey guys, I know this thread is a couple of years old but thought it would be better to post here. On my 2004 F150 SCrew Larait I'm having the same issue with water under both mats in front in that rail where the wires are and it makes the carpet wet. Back mats are dry. I already repalced the 3rd light. The only time it is wet is when we have a good rain. During the summer I took the carpet up and made sure it was dry then put carpet down and it was dry for a good 3 weeks while I was using the AC (then we had a good rain and it was wet again). So I don't think it is the AC. I did remove the running boards a couple of years ago and it was maybe 9 months later I noticed the wet carpet issue but would not think that is related but maybe it is. I will look at the rubber seals around the doors but would both doors go bad at the same time? That reminds me - the drivers side is worse than the passenger side. So the passenger side will have some dampness and the drivers side will be wet. It's always under the mat.
Thanks for the chime in! If anyone has found "the" solution I would really like to hear it. Great Truck but need to fix this issue.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
19
09-13-2017 12:54 AM
Demonhawk
18
11-13-2015 08:58 PM
jw-F150sc
2004 - 2008 F150
03-21-2012 10:58 AM
goldwinger
1997 - 2003 F150
01-29-2008 06:40 PM
gfreek
1997 - 2003 F150
12-08-2004 03:28 PM
Quick Reply: Waters in the wiring channel on the passenger side..
