Tuned my 2016 F250 6.2
I have 1700 miles on my new 6.2 Lariat with 4.30 gears. I had used 5 star tuning on my 2011 5 liter and was very impressed, so why not do it again. I just dumped the 87 octane daily/tow tune and took her for a spin. All I can say is WOW!!! This is the way these trucks should run off the lot. I love the way the tranny downshifts when slowing for a turn. No more lag or gear searching. great job 5 star. Thanks again
I purchased two tunes. Daily/ tow and the performance tune, both for 87 octane. I loaded the daily tune and it's everything I wanted. The truck is so much more responsive and feels lighter, if that's possible. The tranny shift patterns are as smooth as stock, but just a tab bit stronger. I don't feel any adverse conditions or stumbles. I am extremely happy with this setup.
Just do it.....the real truck is waiting to be released.
From my experience the the truck changes right around the 5K mark, so you may want to wait to tune it. I think what you are experiencing after the tune is what my truck feels like after I've been pulling it had it's adjusted to the load. It doesn't take long to go back to it's unloaded mode when running around without the trailer and I wouldn't want it in the pulling mode for everyday driving. With my 4.30 gears I don't feel a lag in power and the transmission shifts smooth and doesn't hunt for gears but my truck had been pulled hard from the 450 mile mark so it may be the way I broke it in.
Denny
Denny
I bought the 87 octane performance tune, the 87 octane economy tune, and the 87 octane daily/ tow tune.
For everyday normal driving with an empty truck, I run the 87 performance. The truck responds a lot faster to the throttle. It also holds the lower gears just a bit longer which is helpful but not so long that it sounds like the engine is over revving. One issue with the stock tune that I disliked was the truck always wanting to go up to a higher gear.
I switch to the economy tune when I am driving to a destination more than an hour or two away. For example, driving from Jacksonville to Tallahassee across I-10. I upload the economy tune put the cruise control on 78 and sit back and enjoy the long, quite ride.
I pulled a small 6x12 enclosed trailer loaded with hunting gear for 4 people from Florida to central Kansas and then to NW Nebraska. The tow tune helped by maintaining gears and not down shifting every time I went over an overpass. It still downshifted on most, if not all, of the elevation changes though.
My previous truck was an 08' GMC Sierra Denali with the 6.2L and was great truck but it needed a tune as well. The manufactures just choke these engines down. A tune really wakes them up and in my opinion gives you what you should have gotten from the factory. Of course some people tune for racing and things like that but that's not why I did it. I just wanted a more responsive truck for everyday driving.
I'm not sure why you think it's contrived but hopefully my explanation helps clear things up a bit.
I only have 32K miles on my truck so I don't know about long term durability or the effects of tuning. However, I can tell you that installing the tune made a world of difference with throttle response, mileage, and shifting.
I have been building high performance Harley motors for 20 years. Each and every motor comes de-tuned from the factory for EPA Standards. The stock motors ran so dam hot that Harley now has a parade mode, which at traffic lights turns the spark off the rear cylinder but keeps dumping fuel for cooling reasons. I have personally tuned over 100 bikes and they are still pulling strong. Some, including mine, with over 80k on the ticker.
Adding a proper tune and opening the throttle body on the 6.2 wakes these engines up to the real potential, not the tree hugging EPA Potential. Adjusting fuel tables and timing is the key, as long as there's no engine knock.
I put gears, headers and a lot of bolt-ons but never used a tuner. The closest thing to a tuner would be a steeda timing adjuster I use on my current GT. Advancing the timing to 15 degrees and run 93 octane gives a noticeable improvement in performance.
Must be a older mustang cause you can't do that to any so called new mustangs without a hand held tuner.
