302 Rear sump oil pan Question.
If you do the front sump you will need dipstick in the timing cover and plug the hole in the block along with the proper pick up that matches the pan. Lots of possibilities with the timing cover. Best thing is get all the parts from 1 truck with same accessories, brackets, pulleys and water pump you want to end up with.
54TexasF100
12-16-2012 09:43 AM
GeorgiaVol
10-24-2011 06:19 AM
Farmall05
03-11-2010 07:54 AM
djmac
03-11-2007 05:46 PM
