Spare tire question
Old 12-29-2015, 07:39 AM
perryau1996's Avatar
perryau1996
perryau1996 is offline
Spare tire question
I have 32 in bfgs on my 96 f150 4x4. I got back to my truck from deer hunting and noticed I had a flat on the rear driver side. My spare is 30 inches. Is riding with this smaller tire going to hurt anything til I can get other tire fixed or replaced? It's really muddy where I am and I will need to use 4x4 to get out. How about 2 wheel drive on the road? Any problems there?
Old 12-29-2015, 08:19 AM
ford300fan's Avatar
ford300fan
ford300fan is offline
In 2wd on highway you will probably be fine. I have a 235/75 spare with 31s. However it might be rather difficult to get In and out of 4x4 cause the axles will bind. Being in the mud is a good thing cause it will let everything slip. It might work with out a hitch.
Idk but it shouldnt tear anything up if you patch/ replace the tire in a timely manner
Old 12-29-2015, 08:27 AM
perryau1996
I had no choice but to put in 4x4. It seemed to be ok while in mud. Very slick. As soon as I got solid ground I put in two wheel drive and it seemed fine there too. Thanks for reply
Old 12-29-2015, 08:29 AM
ford300fan's Avatar
ford300fan
Your welcome , good to hear it worked
Old 12-29-2015, 04:55 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Not a wise decision to run mismatched tires on the rear if you have a limited slip. It will eat up the clutches pretty quick
Old 12-29-2015, 05:27 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Second what Brad said. I would have stopped once you got out of the mud and then moved the spare to the front with the hubs unlocked. Less wear and tear.
Old 12-29-2015, 07:38 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I've also heard people claim that an open diff will grenade if run at highway speeds with mismatched tires for any length of time. Personally I kind of doubt it, but it might be another reason to put the mismatched spare on the front.
Old 12-30-2015, 05:34 AM
perryau1996
Thanks for the input guys. I drove it home 50 miles with no problem it seems. I took it easy. I'm getting a new tire today. Hopefully everything will be ok in the long run.
Old 12-30-2015, 08:48 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
It seems that slightly mismatched tires on the rear would be like driving on a constant sweeping turn, while going straight. One wheel jut turns faster. I dont think it would hurt an open diff at all, but limited slip it would.
dsamuels
2015 + Expedition & Navigator
05-25-2021 09:58 AM
4CFarms
06-26-2013 11:08 PM
awq134
2009 - 2014 F150
03-11-2013 06:02 PM
russ2387
1999 to 2016 Super Duty
20
05-03-2008 02:57 PM
fornarog
03-25-2005 09:16 PM
Quick Reply: Spare tire question
