no crank, no start - 2000 ford expedition,xlt, 5.4, 4x4
Over the last few days I've read a ton of topics and watched a ton of video. I bought this expedition about a week ago. I knew it needed a thermostat as it was stuck open and It had to be started in neutral because of a sloppy shifter. I fixed the thermostat day one and parked it. Temperature dropped 25 degrees to -12 and I went to start and notta. Two days in a row the same thing. Once that happened I fixed the sloppy pedal to make things easier.
I put the key in. Turn it to on. Try to start. Nothing. I hear one click from by the starter solenoid area. (I bought a new one and installed) I also had the dome light on and it would go out completely when cranked. I then started running a test light and volt meter. Battery 12.6 . I got a 12.6 into the solenoid. I did not get a voltage at the time from the ignition but the test light went on when I cranked it to start. Same thing for top of solenoid when trying to start.
I crawled under the suv to check the transmission sensor. It was on neutral. Looked in good shape. Wiring looked covered and in good shape. I tried to take the connector off put I could not get that sucker off. Granted I was very careful because it was 12 below.
I also had the dash plastic off by the steering column and fuse box as to check wires and fuses. This is what I was getting into this morning. Then it decided to start!
I really don't want to get stuck somewhere with the family and have another problem. So I wanted to see if anyone had an Idea about what could cause this? Could my DTRS be going out?
I will have to check that again in the morning. Bumpy roads out here. Maybe there is something wrong with the wire. I moved the wires around quite a bit. I cleaned all connections from battery to starter relay solenoid and changed batteries around to one I just bought a few months ago. Tried to include everything I did
It could be that the starter itself has finally died. Given that the dome light goes out, that points to there being a significant draw on the battery when you try to start it, but the starter not spinning means it could be shorted out.
I would suggest removing it and getting it tested. And when you reinstall it, really clean off the mounting surfaces to bare metal to ensure the starter has a good ground connection to the engine [as well, it also makes sure the starter is properly aligned with the flywheel].
Started yesterday. Multiple times. No start today. I checked connections. Except digging into fusible link. I crawled under suv and no power to starter when trying to crank. I put screwdriver on bottom of starter solenoid only in attempt the old screwdriver trick and it started with it just on bottom. I disconnected battery and cleaned up the wires some more. Put original ford nuts on there instead of replacements. Connected battery. Then it fired right up.
Any thoughts?
Any thoughts?
92 Red F150
08-12-2010 12:17 AM
