97 F350 7.3 trans problems...
The automatic trans in my 97 f350 is acting up. The truck is not worth paying for a rebuild so trying to find any other option. It slips once warm, no particular gear. Today with about 3k lbs of trailer behind it, the truck stopped in its tracks. Removed the trailer and drove the truck home.
The dipstick is missing and I cannot locate the correct one at a local yard but am trying.
After I verify fluid level would you guys recommend a fluid and filter change or would I be wasting my time?
Just wanting more thoughts on this. Thanks
if it stopped in its tracks its probably too late, personally I wouldn't even drive an automatic without knowing the fluid level is ok.
you could stick a van dipstick tube into it if you take the stick also, yeah its going to look funny but it will get your level where it should be and might be able to find an old rotten cube van with a powerstroke in it at a wrecking yard.
might be worth a fluid/filter change, its a shot in the dark if its already stopped moving.
good luck.
good luck.
When I bought the truck a month ago the seller was checking the fluids in a hurry and is thinking the stick fell out in the road during his test drive. He said it had fluid but was a little low so if he is correct fluid level should be fairly accurate because it doesn't have a visible leak.
brian1080
10-19-2011 09:12 AM
