low pressure pump
Very easy. Drain fuel. Disconnect 4 fuel lines (Ford fuel line removal tool for two on the right circled. Can be purchased at Advanced, Autozone etc.). The other two have clips that you engage by pressing both sides with your fingers. Unplug the electrical plugs. Remove 3 13mm bolts on the frame and she is out. Removing front driveshaft makes it easier but isn't necessary.
anthonym92
05-31-2017 05:38 PM
westcoastslider
10-26-2008 05:43 PM
DJdemon6696
27
12-02-2007 04:43 PM
