Door Map Pockets
Old 12-28-2015, 05:03 PM
goblue74's Avatar
goblue74
goblue74 is offline
Door Map Pockets
First post, but have been collecting information from you guys for about 2 years.
1974 Ford F100 Ranger, 360 Automatic. No rust through, just the normal surface stuff on the roof and hood.
Ok...question I have is I am installing a set of map pockets on the doors below the door panel. I finally found a set of blue ones in great shape. Can anyone tell me the hole size in the door that the plastic clips fit into?
Thank you much,
David
Old 12-28-2015, 05:07 PM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
HIO will be along shortly. Please hold! You may hear a series of clicks, but please do not hang up the phone...
Old 12-28-2015, 06:26 PM
scottscott's Avatar
scottscott
scottscott is online now
Off the top of my head, the holes are 1/4". But, I'm not going to pull my map pockets off to double check! Drill a 1/4" hole in a piece of scrap (lamb tough dodge) & see if the push in clip fits.
Old 12-28-2015, 06:43 PM
goblue74's Avatar
goblue74
goblue74 is offline
Thanks Scott,
Can you tell me if yours has 4 or 6 clips? Each that I have have 4 clips, but 2 empty slots along the top edge.
Hoping the picture will post.
Thanks again,
David
Old 12-28-2015, 11:35 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Say what?
LOL.
Old 12-29-2015, 07:31 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,288 Likes on 2,444 Posts
I will eye ball the spare set of pockets in the shed and count the press in clips (X mas trees). If I can find the door they came off of I will measure the holes.
Old 12-29-2015, 05:00 PM
77&79F250's Avatar
77&79F250
Ok found out that my parts bronco had them, well at least it has the 6 holes. And yes they are 1/4 " diameter.
And my blue map pockets on the shelf, have or had at one time, 6 mount push pins.
Old 12-29-2015, 05:39 PM
goblue74's Avatar
goblue74
goblue74 is offline
Thank you 77&79F250,
Found some clips to fit into the slots along the top, made a cardboard template and drilled 1/4" holes. Snapped right in. PO of the pockets had 3 extra holes in each one so added the extra security with some trim screws.
Next will be to freshen up the door panels.
Thanks again!!!
Old 12-29-2015, 06:47 PM
77&79F250's Avatar
77&79F250
No problem, here are some door panel "freshen up" paint scheme or other ideas.
Old 12-29-2015, 07:05 PM
goblue74's Avatar
goblue74
goblue74 is offline
Thank you....hoping to find some decent interior correct Ford blue paint for the door panels. Gonna do some research before bothering you guys.
David
akuhr93'f150
16
07-23-2015 03:22 PM
nevaplayedk9
03-12-2015 10:01 PM
jrockdiddy
12-31-2014 06:17 PM
egarage
12-22-2012 07:18 PM
fordxxx
Paint & Bodywork
09-02-2004 02:56 PM
Quick Reply: Door Map Pockets
