No oil pressure at idle
2003 6.0 diesel with 200,000 miles runs good start easy but does not show oil pressure at idle (intermittent problem that has been occurring more often). It has ford oil filters and ford oil with about 3500 miles on the oil. The check gage will come on and the oil pressure drops out if you give it some throttle it comes back but will drop out again at idle. But like I said the truck runs perfectly fine and the icp shows pressure all the time.
Ironically I am having the exact same issue that began last night. I'm in a 06 6.0. Is there any way to monitor low pressure oil pressure from the PID's using torque pro or SGII. Also i believe mine is an electrical problem as i had had issues with the Tach not reading properly on a couple occasions.
If truck starts and runs fine you might have a bad EOP sensor, which in reality is just a switch that will move the needle to the middle range once it reach's 7 psi. If you didn't have that much you won't even begin to feed the HPOP.
Pretty sure there is no PID for the LPO.
Might also check to be sure the little black plastic valve under the oil filter is not broke. You will have to remove the filter to inspect.
My truck did this one before about a month ago when i had a coolant hose I didnt get tight so I thought it was just a wet sensor. Now since I live in OK and monsune season hit christmas night and now I am having the issue again. Truck starts and runs great. IPR and ICP numbers are right where they are supposed to be even when the oil pressure drops out.
04 6.0 Runs good then Oil Pressure Drops out
My Baby Its the Last Thing My Dad Got for me before he Passed July 3, 2020 Please these Truck means A lot to Me !!
Hi I am pulling My Hair Out . My 04 f250 6.0 is doing the same thing Runs and when the temp gets up the oil Pressure Drops Out . I have Changed my ICP Sensor , Oil Pressure Sensor , Pig Tail to my Turbo , Was told High Pressure pump is a maybe ? Hope not my Truck was Studded an Deleted by the Best In Texas !! I only have 183k on a Well care for 6.0 . Any Input would be greatly appreciated!!
As I posted there:
Tell us where the ICP sensor is located on your 04 engine and then tell us what brand of oil filter cap and oil filter you are running.
AND - Take a picture of the top of the engine and post it. It can provide us with some information that might help.
It is hard to understand your approach to getting help.
Edit - the person above Hartwig's post is probably a troll ...............
Blackberry farmer
11-12-2011 05:30 AM
