goes into limp mode
fuel rail pressure too low.
air in the system...primary filter could be non OEM or OEM and installed wrong
clogged primary filter
defective primary lift pump
clogged secondary filter
water in either filter that gelled, froze, and is clogging the system
defective high presure fuel pump
also be advised, ford put fuel tanks in their f and e series vehicles up until 2009 that eventually have linings that break down and fill the fuel system with flakes and rust.
you should stop driving this vehicle until this is professionally looked at and resolved.
this could wind wup being a costly repair.
menze46
10-19-2019 10:33 AM
