zf5 issues
zf5 issues
Tranny has gotten a little louder last few days. Took it on a trip to the city today, about 200 miles. On the way back it was getting louder then I got on it in traffic. Now 1,2,3 & 5 make a horrible knocking noise, similar to a rod knocking. I would say flywheel or clutch but it's dead quiet in 4th. I think 4th is 1:1 ratio so I'm sure that has something to do with it. Any guesses on what I tore up now before I tear it apart tomorrow?
I can't remember what the beating is called someone will chime in with the name, the bearing between the input and output shafts. It is located in the input shaft inside the tranny. While driving that is the only bearing that is not moving in 4th gear because the input and output shaft are coupled together.
I would find it really hard to believe it is a clutch weither smf or dmf with it being dead silent in 4th but really loud in all other gears
ZF S5-42 Questions
I'm deviating from the initial post, but I have some questions that I can't seem to find the answers to. Maybe some of you experts can educate me. 1) I have a ZF S5-42 tranny hooked up to a BW1356 transfer case. I cannot seem to find a manual shift linkage ANYWHERE for this combination. 2) I had a C-6 in my truck before the ZF. Now I can't figure out how to hook up the backup lights. O'Reilly's and NAPA both gave me a switch that was listed to work in the ZF transmission, but there is no place to install it. Any ideas out there?
The reverse light switch is located on the drivers side, about 10-12 inches back, towards the top of the tranny. It takes a 2 wire plug/pigtail, which I have purchased from NAPA.
