New 51 project
New 51 project
First time restoring a truck. Have done several mustangs and working on a 68 camaro. Have always loved the 51-52s. Here's my question. I just imo scored a 51 f3. Not rust and in really good shape. I want a f1 because I love the looks. Where the rear fenders run all the way to the rear of the truck box. But for the price I couldn't walk away. Can anyone send me a link for shortening the frame of the f3 to make the f1 box and fenders work. Making a driver not for show. Will be welding in a new front crossmember for new suspenion and will be going with a new 9in or 8.8. Just need help with shortening the frame correctly
Welcome the the forum. The best one on the planet for what you are doing. Plenty of people on here to help you out with this.
I'm a newb myself for these trucks and I'm working on a 52 F3. The bed and running boards are super hard to find so please don't scrap them. Plenty of guys on here would love to take them off your hands.
Good luck with your project!
Scott
Scott
Welcome to the forum! There's no big secret to turning an F3 into an F1. The big difference is the 8" in the wheelbase you need to remove from the frame rails right behind the cab, from 122" to 114". There's a bit to bob from the tail of the rails for the bed to fit, but that's about it. The important part is making your cuts even and square, and doing a good, safe job of welding the halves back together. You're probably aware that the wheel openings are different size between the F1 and larger trucks. If you use F1 rear fenders, (which is mandatory with the F1 bed) you'll need to procure a set of F1 fronts to match. Otherwise it looks kinda goofy and unbalanced with big openings in front and small in back.
Good luck with your project.
From montgomery, al. Thank guys. I knew I would need to replace the fenders on the front and back. So when the times right I'll let the f3 bed, fenders and board go to a good home. My concern was with shortening the frame. I was also looking at installing and welding in a aftermarket front suspension Mustang 2 style. I am assuming that the frame Rail width on an F3 is the same as an F1. All the aftermarket front suspension kits show to be for F ones. Will they fit my F3
That is a very nice looking F3. I am an F1 guy however if I owned that truck I would not change it. I do not see visible rust in the usual spots, appears to be very solid. Changing it to an F1 the only thing that you are buying (have bought) is the cab that you keep as is. The fenders running boards and bed are all different. If you do change it to an F-1 there are guys on this forum that will buy all of the non F-1 sheet metal and be thrilled. IMHO keep it an F3.
I am also one of the people who think you should leave it an F-3. When you go to car shows or on tours you see a lot of half tons. How many bigger pickups do you see? Many of us on this forum think the F-2 & F-3 pickups are really neat, under appreciated trucks.
That truck looks really nice. If you do end up converting it be aware that the F-2 / F-3 frame is taller and thicker than an F-1 frame. The width is the same as the F-1.
Here is a picture of my F-2 for comparison (and hopefully nudge you a bit toward keeping your truck a 3/4 ton):
