Only have 1 gear when OD is on, and 2 gears when OD is off.
Old 12-26-2015, 02:00 AM
RH412's Avatar
RH412
RH412 is offline
1997 F-150 4.6 V8. I was driving one day going 45-55 and all of a sudden my RPM's went up and lost acceleration. Since then, when overdrive is ON, it stays in 1st gear and doesn't shift out but the RPM's just go up. When overdrive is OFF it drives in 1st gear, and feels like it shifts into 3rd gear around 12-15 MPH and stays in that gear. When I come to a stop it does the same, like I only have 1st and 3rd. It gets to about 40 before RPM's are really high. I heard one of my solenoids could just be burnt out. Also, there is no transmission slippage, it shifts fine with no odd noise.
Old 12-26-2015, 07:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
The first thing to do is to get the codes read. The places that read codes free CANNOT read the codes that you need. You'll need to pay a good independent shop or a Ford dealer, or find someone near you with an Auto Engenuity setup.
manwithavan
30
07-11-2017 09:16 PM
DAT2109
11-27-2013 01:38 PM
trailer-truckin
05-13-2011 12:31 PM
DarrellJ
10-30-2010 04:45 PM
Like M. Fords
15
05-04-2008 06:43 PM
Quick Reply: Only have 1 gear when OD is on, and 2 gears when OD is off.
