Tank Selector Valve Rebuild with some pics.
Don't know if anybody has busted one of these apart yet. I would imagine so. I took one off of my truck that wasn't switching, and decided to see if it could be fixed. Dang thing at the ford house is like $480.00! I don't think so! So, I busted it apart to see what went wrong. I would appreciate any input. Keep me on the right track. Pics and stuff next.
I just drilled out the 1/8" rivets, and it snaps apart. the contact surfaces shown are for the motor power. They look like they are having a bad connection problem. The other side has contacts for the fuel gauge. I took some crocus cloth and cleaned up the contacts. Then polished them with a pencil turned around in a drill. The eraser will polish the heck out of copper. There are a couple of diodes down inside, you could test those with a ohm meter. If they are good, it will read short one direction, and infinity the other. If they ready infinity both directions, or ohms in both direction. They are trash. Cheap part, easily changed if so. I could use a wiring diagram, if somebody has one, for an obs diesel? I used to have one, can't find it. I got everything cleaned up, I'll get some dielectric grease to put on the contact surfaces. That keeps them from building up carbon, it is a must. I will keep posting on this, until it is fixed and done. Or, in the trash. lol I hope it helps somebody save some money. Not much to these for $480 freakin dollars!
Ha ha ha, I have absolutely no use for that much fuel in one sitting. If it's a trip I'm taking, I don't mind stopping every few hours to stretch my legs. I'm a tad on the tall skinny side. Lol
Never really thought through this much, but it would be worthwhile to toss in a large capacity rear for that sort of change holds more than the duals do anyways.
There are quite a few quality 6 or 4 port fuel selector valves out there that are much cheaper than our factory unit. I'd rewire the switch to an updated valve and be done with it.... or run 1 tank.
Cant beat the price on the tank....
