Duh!
Duh!
Been having problems with my 97 F350 CCLB 351W. Spitting and sputtering under load, no power, etc. New plugs and wires made no difference, neither did fuel treatment or new fuel filter. The other day I was going up a small hill and for some reason decided to try switching to the rear tank (I've been running on the front since I got it because I had no indication the tanks were actually switching since the gauges don't work). Well, the truck took off like a shot! Obviously the front pump is going. Plans are to replace front pump and fuel sender unit. The question is so I do like I did on some other trucks and make life simple by cutting and access panel into the bed floor, pull the bed or drop the tank. I'm leaning towards cutting. Thoughts?
Personally I wouldn't cut anything. It just ends up looking like a hack job. Getting the bed out of the way certainly makes it easier, but generally removing the bed is hard enough that overall it's a bigger job that way. I replaced the rear fuel tank on my truck just working from underneath. Yes, it's a bit of a pain, but that's the way I'd do it again if I had to.
The exception to that is if I had a few different things to do all at once (like both tanks, rear spring hangers, brake lines, clean and paint frame, etc) I'd pull the bed to make all of the other jobs easier. But if I was only tackling one tank I'd fight it from below.
speakerfritz
1999 to 2016 Super Duty
12-13-2015 02:25 PM
nc150
15
08-10-2007 11:57 AM
