97 up-pipe repair
Old 01-02-2016, 06:19 PM
fordman67's Avatar
fordman67
fordman67 is offline
Believe it or not they blast quick and clean up nicely. It's like crap gets burned on the outside but is just on the surface.
Old 01-02-2016, 06:35 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Originally Posted by fordman67
The stock pipes are stainless.
Good to know...now I know what sort of welder I need to find.
Old 01-02-2016, 07:33 PM
madpogue's Avatar
madpogue
madpogue is offline
Originally Posted by Red454sedgwick
I'm going to have to stick a magnet to my pipes then. as rust as they are I just thought they were steel. if they are stainless it must be a low grade of it
What would a magnet tell you? Stainless STEEL contains enough iron to attract a magnet.
Old 01-03-2016, 12:21 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
I can't explain the physics of it, even though they both contain a lot of steel, 300 series stainless is very slightly magnetic, 400 series is more magnetic, but both are dramatically less magnetic than carbon steel. You can easily tell if a part is made from stainless steel using a magnet.
Old 01-03-2016, 09:13 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
No input on the cut, revers and weld?
Old 01-03-2016, 09:54 AM
fordman67's Avatar
fordman67
If you have ever had a set out believe me I only want to do it once.
That method would be IMO better than swelling the pipe up though.
Old 01-03-2016, 01:45 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Cheap fix for the short term.
Fel-Pro 8194 Up-pipe Gasket Set
Old 01-03-2016, 10:16 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
My thinking would be to find a suitable donor beforehand...I presume they would be cheap and easy to come by?
Is it one side or both that are susceptible to this pitting issue?
This could also be an niche business if someone had a TIG welder, a way to provide backing on the inside surface of the weld and a spare set of up pipes to repair, ship and charge a deposit for.
Old 01-03-2016, 10:54 PM
fordman67's Avatar
fordman67
Bellowed up pipes fix the issue permanently. Otherwise it's just a bandaid on a shotgun blast
Mark Alligood
12-19-2012 08:01 PM
ff1210
Ford Truck Parts for Sale
03-10-2011 08:34 PM
97powerstroke350
06-28-2010 03:34 PM
hedhntr
06-24-2010 03:37 PM
kawa
03-23-2008 12:40 PM
Quick Reply: 97 up-pipe repair
