Interesting Idea for a Switch for Bed Lights
I will be installing LED bed lights and have read almost every post on the net about ideas for wiring the switch. I am leaning towards a power wire from the battery to a switch at the rear of the bed, The main concern folks have is forgetting to turn it off and killing the battery.
So I started looking for a switch with a timer and came across this device. http://www.wolstentech.com/products/timedelayrelay/tdr-mc.php It is a integrated relay and count down timer. Just toggle a momentary switch and the device will turn on the LEDs and start counting down. The timing is variable. If you toggle the switch again the timer will cancel and turn off the lights. I ordered one to see how it may work.
I also found a switch and timer module used for rear window defrosters. I thought about sourcing a junk yard switch but found out that the timing circuit in most cars is located in the computer or instrument cluster. Anyway, this device is all contained, counts down for 10 minutes, probably is cancelling, and even comes with a switch. This may be a better solution. https://www.frostfighter.com/thermas...r-controls.htm
Thoughts?
Thoughts?
That was my plan, I even have the switch. But Mr. Murphy hates me and would love to kill my battery. I'm the guy that stuff happens to.
Alternate Bed lights wiring
I have LED bed lights on my Crew Cab. I wired them into the cab step light connectors that were capped off under the truck. The connectors are on the outsides of the frame rails about 8 inches from the back of the cab.
These connectors are energized and work with the cab lights. So if I open the doors or turn on the cab lights manually in the cab - my Bed Lights turn on. What's also great is that they also turn on when I unlock the truck using the key fob. Granted they only stay on for 30 seconds when activated this way, but it's come in handy when I just need to find something relatively quickly at night. If I need light longer I just need to hit the unlock on the key fob again...
My truck is an XLT with "Premium Package" - I don't know if the connectors are installed on XL versions.
They automatically turn off with the rest of the lights - and it looks kind of cool because the dim to off.
I'm also doing bed lights at the moment and what I want to do is get a switch for the negative so when the tailgates up the negative is disconnected and when it's down its on but inside the cab I'll have a button for the positive wire that will always be on but whenever you have to leave the tailgate open around town flip the switch off in the cab. Or for an easier way I was thinking wire it directly into the cargo lights and you can just hit the unlock button to turn it on for about a minute and if you need longer crack a door. If you come up with any other ideas be sure to tell me
I considered these as well. Plunger switch plus an in-cab switch is over thinking the project in IMHO. A simple switch with time out near the tailgate solves the open tailgate issue. I don't want the aggravation of making the cab switch is "on" when I open the tailgate. I also don't want to crack a door to keep the light on. Good ideas though.
